1.6 wiring harness work on 1.8 gti engine?
(In Topic #143829)
We just bought a 1.8 GTI 8v engine for our mk1 golf, but we didnt get any wiringharness with it.
Does the wiringharness for 1.6 work on the 1.8 gti?
www.sviddgummi.no
you can even add it back in if you like its dead simple. splice 1 wire to coolatn temp, 1 wire to an ign live. then its 1 wire to level sender and the other wire plus relay earth to ground. simples.
But I assumed the op meant the car is a 1.6 gti already and you want to swap in a 1.8 gti lump though, if not main issue is making sure you get the right loom to match the fusebox
Yeah its a 1.6 but not GTI, but the 1.8 is a GTI so it would be a non GTI 1,.6 harness on a 1.8 GTI engine. Thats the question
www.sviddgummi.no
ideally you need a rear gti wiring loom too, but you can add the pump wiring if you want. depends how good you are at wiring
the rest of the wiring is fine, dash, lighting and the rest.
Anyone here selling one?
www.sviddgummi.no
