1.6 GTI, MPG in low 20's, Help!
(In Topic #92991)
Set timing accurately to TDC (Correct for 1.6 GTI)
Oil and filter changed, VW synta silver
Fuel filter changed, Mann item
Distributor cap & rotor changed (GSF)
Magnecor 8mm HT leads fitted
What should I look into next? Warm idle is fine, around 950rpm. Some small poppings are heard on the over-run. CO is not too high. Tyres are inflated etc etc!
How easy is it to check valve clearances on the shim-tappets? It's the only other thing I can think of which is giving the poor MPG!
See previous ramblings /answers on my other thread:
http://www.vwgolfmk1.o…ms&file=viewtopic&t=18706
Unless maybe my speedo/trip-meter is way out? Would affect milage reading. Got original wheels and tyres though :dontknow:
It's just getting expensive, ?20 for 80 odd miles
ht leads and plugs will play their part too.
?20 for 80 miles? shocking, but as said, how are you driving the old girl? spirited round town driving?
funny how the 1.8s give better economy
CO was checked at MOT time, had 2 computer print outs on different machines, both saying it's quite low CO.
Think the 1.8 has different crankshaft/stroke, and different cam. But then again, you hear of tuned cars also returning good MPG figures.
I will update this in the near future with what I find, may be useful to other 1.6 GTI drivers. Cheers
what figures were they? if the mixture is too lean it can affect fuel economy.
hope this helps cheers
jonny
Mark 1 Golf GTI 1982 1.6 owner!
Mark 2 Golf GTI 1986 owner!
Elfboi7 said
I had the same prob with my 1600 gti about a month back….its most likely your mixture as people have already stated or its the pressure regualator sensor that hasnt got power or less than it should…mine had 2 volts witch made it run as it was cold all the timeQ my advice would be check all the voltages to the senders…
jonny
Ive got similar probs with my 1800 lol, wheres this sensor mate?
(sorry to hi-jack)
<a href="Image hosting, free photo sharing & video sharing at Photobucket"><img src="http://img.photobucket.com/albums/v312/biggaz/hezzasig.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
mk1 Jetta GTI Spec.
mk1 Jetta GTI Spec.
mk1 Jetta GTI Spec.
mk1 Jetta GTI Spec.
