1.6 gti cut out when driving now wont start :(
(In Topic #141218)
I started the car when it was warm and it was a little difficult to start but did start eventually and sounded fine, i let it idle for a few minutes to make sure it was happy. i drove about 200 metres went round a round about went to change gear and it cut out on me with no warning at all. now it wont start i have left it for a few hours so it is cold and still wont start. it turns over with the key nice and quickly.
im sure it is a fuel problem but any suggestions will be helpful as this is my first mk1 gti and i learn something everyday about it.
i have recently (in the past few weeks) changed:
battery
Spark plugs
dizzy cap
ht leads
cambelt
airfilter
new oil
oil filter
And the car had 1/4 of a tank it at the time, i have put 10ltr to see if the fuel gauge had stopped working and the fuel gauge is reading fine.
Any help would be greatful.
i miss driving her already lol
cheers Alex
thanks for the input
Campaign Mk 1 Black
16v Mk2 Red (decsd )
you need to test it is sparking, watching it go round won't tell you much, put the cap back on and remove a lead from a plug, put an old / spare spark plug in the lead then place it on the rocker cover and turn the key and see if the plug sparks.Bloomers said
i took the dizzy cap and watched to see if it went round when the engine turned over. Is there a better way of testing it?
don't hold the lead while your turning the car over though you might get a shock!!
Regards Volkswarren
Campaign Mk 1 Black
