1.6 abf swap
(In Topic #130567)
1.6 abf swap
you need just the engione loom from the abf, plus the ecu and the bit of loom on the block itself. basically if it has the ecu plug and fusebox plugs on thats everything you need from the abf wiring wise. if its a 96 ecu you also need the immob box with a matched key, plus the loom from it
