???????????little stutters while running,why???????????
(In Topic #72549)
Say after the h0se was changed after the water leak incident, the car is running fine!
maybe Im been a bit fussy, especially when the car is 22years 0ld, but there is a little thing I n0ticed!
And that is when the car is running well 0n the m0t0rway, when surging a bit m0re gas 0n the pedal I feel 0dd stutters!! yep, stutters but n0t big cutting 0ut stutters th0ugh! I cud live with it, but what can this be?? and is this seri0us?? and what cure??
The car is running 0n Shell unleaded, and the car has had a service!
what d0 y0u say guys??
N0rm
I suspect that is the HT leads on my other car so I will be swapping those for some decent new ones shortly - maybe you should get the HT leads checked on your car?
Cheers,
Chris
Life Member
"Volkswagen officially state all Mk1 Golfs can run on unleaded petrol with a octane rating of 95 RON or higher.
If your Mk1 Golf is a GTi, then using 95 RON unleaded will require the ignition timing to be adjusted as follows:
1.6 (EG) engine 6 deg +/- 1 deg ATDC
1.8 (DX) engine 0 deg +/- 1 deg BTDC
If you modify the ignition timing, you must mark the vehicle with a sticker PN 000 010 007F on the petrol cap/filler.
Using 98 RON unleaded will not require any timing adjustment.
If your Mk1 Golf is not a GTi, you can use 95 RON unleaded wihout any ignition timing adjustment. "
Rajan
