'83 gti will not run...
(In Topic #101319)
Now were stumped….this is my first VW and it's really being a pain. Any ideas??
When it's chugging at low rpm…the engine "pulses" strongly which fluctuates the rpm between 200 and 600. the injector press. rises with the higher rpm but falls quickly when it slows down. which leeds me to believe the air sensor is working. Not sure if the injectors are actually firing at all. also tried several other ideas like…turning the ignition distributor, unplugging the o2 sensor, lifting the air box off the bottom section, plugging the brake booster(vac leak) and re-gapping the plugs. with no noticable difference. I also added a shim to the pressure spring in the fuel distributor with no noticable difference.
At this point a carburetor conversion is looking pretty sweet…..my initial thoughts on how cool the cis was are quickly going down the crapper. What the heck is going on here?
Just a thought?
What are the fuel pressure readings - system pressure, and control pressure (cold and warm), and the temperatures you took these at.
system pressures
During all of this, there is no pressure to the injectors. With the previous parts it would fluctuate around above 35psi. If I wedge open the air sensor plate it will flood the engine. I talked with a local VW performance shop and he said the weber 2bbl carb conversions are "junk" and not recommended. He recommended fixing the cis and forgetting about the carburetor. So I guess I'll just keep on trying here….oh yeah, the temperature was about 75 (F) when I checked the pressures.
I really appreciate all the tips and suggestions from you all here. Thanks!
Also you need a valve in it (after the gauge but before the WUR) so you can measure the system pressure.
You're kinda half way there with the WUR-metering head connection but I think you only managed to measure the control pressure, which varies with temperature…..
Try a search for "fuel pressure mechanical K-Jet" or something like that, see if you can find a pic of it - it will really help!
I also verified ignition timing with a timing light using the marks on the crank pulley. I verified operation on the cold start valve with a test light and by checking for fuel. although I'm not sure how much fuel is supposed to be coming out. I pulled all the injectors and set them on the valve cover…with pump on and pulling up on the air sensor I have fuel coming out and they're making the high pitch noise. The one thing I did notice was when checking the cold start valve. I noticed no difference with the wires off or with the whole valve removed and hole plugged…car stills starts every time but will not run. Tried another valve I had and still no difference. does it mean anything?…I don't know.
- Mixture
- Compression
are the only 2 things left, which would make it not run
Unless you've done something like the igition leads arean't connected correctly…
Auxiliary air valve operation
Thanks again, for all the help. For once I feel like i'm making progress here.
Obviously if you're taking a CO reading at idle (to set the mixture), then you need to be approx at the rpm for idle, but its not a critical thing.
update
With the heat building up soo fast in the top end, am I still looking for a mixture problem? Or is it timing?
heat wise, it's hard to say if your cars getting too hot from the description. heads and manifolds do get scolding hot.
what pressure did you measure at the injectors?
though it sounds to me like you are running lean, i can't help but think that there is a timing issue going on somewhere here.
Rabbit update
I did come across an 'ol vw mechanic from back in the day….we talked a while about the car. He said the car should've ran with the bad rings, but obviously not that great. He suspects that the frequency valve is stuck or not operating. He showed me on his cherry Scirroco how it should sound and briefly explained what it does. I know for a fact my valve was not making that noise. So when I start working on the car again I'll fix the piston/rings and troubleshoot the valve. Maybe in a month or two I'll have some good news to post.
Lastly, in a bout of good luck I have aquired a rebuildable '87 Jetta GLI engine for free, plus a huge box of cis parts and two boxs of professional grade repair manuals. And yesterday I purchased a '91 Corrado G60 parts car minus engine/trans and some body panels for a mere $300.
