Wonderful Pierburg 1.8 clipper cut out issue
(In Topic #81207)
I was half aware of the issue before purchase and have a spare carb to fit (unfortunately not a Weber…). But, from looking at similar posts, it looks like a good clean of the throttle body will help no-end…
…However - I'm a mechanical novice and couldn't even find the idle control screw earlier (thought I'd run rich/high idle as a temp fix). Can anyone give a newcomer some step by step instructions/diagrams to:
a) locate and clean throttle body (found good one for mk3 golf, but not mk1 clipper)
b) replace pierburg like for like; and
c) replace dreaded pierburg with weber (manual choke???)
Any help/advice would be much appreciated!
Thanks,
Carl
______________________________________________
I have been through the same as you. Spent ages taking the Pierburg apart and replacing loads of parts - wax stat, 3 point unit etc. Never did really get it running properly. In the end, I went for the Weber 32/34 conversion. About an hours job to fit and never looked back. Also, I prefer the manual choke which does not leaving the cold engine revving at 2500 rpm !
Steve
'83 GTI
'06 SAAB 93
'91 Cabby (Sold)
'92 Cabby (Sold)
'06 SAAB 93
'91 Cabby (Sold)
'92 Cabby (Sold)
