which carb have i got?
(In Topic #142193)
what can i do to make my car run perfectly :dontknow:
That could be timing belt, I think.
A low rpm, yes that may well mean your idle speed needs to be adjusted an I'm sure that's to do with the carb.
What's your engine code? As an example I have an 1.8 EX carb engine, this would have used a pierburg which i think is also known as a solex/zenith carb or even a weber but that's a mod I think.
Sorry to not fully answer the question but I'm not really an expert. I do have a Haynes manual for the pierburg/solex/zenith, an I might be able to tell you how to adjust the idle speed an what not an maybe the timing, but it could be slow going if we both don't have the required experience if you get me.
Kind regards,
Didge
I'm so flipping lonely, it's killing me lol at least I can laugh about it!!
il find the engine code and get a picture up of the carb
cheers so far :wink:
I'd say it's stll a combo of the timing belt an the carb settings.
I think if your facing the engine bay/carb with the filter off the idle screw might be on the lower left hand side. I'll see if I can find an Image of a pierburg carb for you on google.. Brb.
Right, I've just found an expaned image which was provided by rubJ he always know what he's talking about hers the link: http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=61457
see where this gets you, as if you can raise the enine speed then you can find out if the timing is better, see because the engine is running at such a slow rate the engine might be just backfiring because of fuel hanging around an that it's not burning proper.
Hope this helps,
didge
sorry using the iPod thing an it's thewordt thing ever to surf t'internet lol
