WHERE TO BUY PLASTIC BREATHER/VACUUM PIPE+rubber sleeves?
(In Topic #135740)
So yeah, as title says, I'm looking for the best place to get the white plastic pipe for vacuum unit to carb and the engine ventilation pipe etc. It's for my Mk1 Jetta with running issues so I wanna eliminate that as a cause, it looks to be all quite thin and the same gauge all round (3mm). Also need to replace rubber connecting sleeves which are cotton braided on the outside.
Heres a pic of the same tubing on someones else's car;
WHERE TO BUY ONLINE, OR AROUND CENTRAL BIRMINGHAM? - for cheap!
Cheers,
Kennedy.
AND yes Moderators this is the same post as in the small block section, but I'm getting no love there.
rubber is fuel hose. from halfrauds or GSF or any other motorfactor.
novocaine said
pipe from aquarium store.
Might collapse under vacuum?
The braided hose should be okay to get hold of I suppose as long as I can find some with 3mm internal diameter. I will see what VW are selling it for anyway.
The real problem is this 3mm rigid white pipe/tube, I think it is gonna need to be plastic type and not rubber as it could very well collapse under vacuum/suction.
Any more thoughts on this?
KND
if it helps heres the stuff in 25m roles. enjoy.
http://www.airlines-pneumatics.co.uk/webcat/Detprod.asp?ProductCode=S08000105
or 30 m for 8 quid.
http://www.plastock.co.uk/Hose/Nylon/Flexible/3x-1-5mm-NYLON-FLEXIBLE-TUBE-p2413.html
and halfrauds still stock the braided stuff. i've got a role in the glove box.
novocaine said
my advice was based on doing it.
or 30 m for 8 quid.
Well done Novocaine, thats exactly what I was after. Got 30metres coming from www.airlines-pneumatics.co.uk cos they have cheaper shipping options.
Thanks all, case closed
KENNEDY.
1980 Series 1 GTI (gone now .. what a mistake selling her!)
1979 Series 1 LD - the Mandarin Dragon … gone as well. oh dear.
