Where does this wire go? 1.8 Clipper
(In Topic #148461)
I need a little help please:
I have been fixing a few broken wires and cannot work out where the Yellow and Black one goes shown below in the Yellow circle? The Black wire next to it goes to the part throttle channel heating element on the front of the Pierburg carb.
dont know how to post pics but can email some pics if you wish.
haysy02 said
on mine the yellow/black wire connects into a spade plug with the single black wire that runs to the carb. possibly the one that you have connected right next to it.
On mine, the two wires (black one and yellow/black) are crimped together (looks original) to a single spade plug. Is this what you are saying?
Err… what would happen if the part throttle channel heating element was never connected? I vaguely remember wondering what this unconnected wire was when I started the usual coolant channel o-ring change. I'm having stalling problems that haven't been solved. I also can't see anything to plug it into - will have to take the carb off again and examine it more closely.
Prepare yourself for me asking for some pics too if I can't find the socket on the carb..
Has probably never been connected since we've had the car (about 3 years) and it had been running ok-ish (bit of a fast idle and the occassional stalling on hard accelleration).
Thanks for the photo - It looked like it should be easy to remove, one screw.
just curious though. in the same location as them wires i have a red/white wire with a plug on the end that isnt connected. i did look for somewhere for it to connect to but couldnt find anything. but the car has run fine.!!
