where can i buy an expansion , waxstat ,thermal valve 2e carb
(In Topic #152777)
where can i buy an expansion , waxstat ,thermal valve 2e carb tried everywhere no luck cf_emoticons__BangHead:cf_emoticons__BangHead:cf_emo
not cheap, but genuine:
http://www.vwheritage.com/vw_spares_Waxstat-for-Pierburg-2E2-Carburettors-Golf-Jetta-Caddy-026129243C_act_shop.product_pID_100108611_lang_EN_country_GB.htm
Hi - I have a spare one I'm case mine goes. I Need to keep one spare, and may have a second one. If so then I'll let you know. I got my spare by buying a few 2e2 full carbs from eBay. You then build a nice little stock of spares. There is one on there at the moment. They come up quite a lot
http://www.ebay.co.uk/itm/vw-golf-mk1-clipper-cabriolet-1-8-pierburg-carburettor-/151007256269?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2328bbdecd
Cheers lads vw heritage is out of stock tried pages and gsf they dont sell them :-/ been watching a few carbs on ebay think thats the way forward thanks but if you do have spares it would be a massive help
Red Cab, rubjonny has a thread regarding refurbing the 2e2 carb which I went through this weekend as mine was being a right bu99er on start up. I found the main issue which was a pipe off the back of the carb, cheers rubjonny I've noticed that my waxstat is also faulty but in his thread he mentions this :
Waxstat, also known as 'Expansion Element':
Helps control the idle until the autochoke switches off completely. Is full of wax which is heated by coolant. As the wax expands a pin exends from the unit pressing a lever which brings the idle down. Check by throwing into a bowl of hot water, the pin should extend. This has been known to fix dodgy units as it 'resets' the wax apparently!
No confirmation it works (anyone??) but I hope to take it off this weekend and giving it a try, nothing ventured . . . . .
I no longer have the Mk1!! I now whizz round in a Black 1990 3dr Mk2 GTi 8v but the roof doesn't fold back when the sun shines
hi lads (update) i found one
TPS in shelf (halifax ) who were really helpfull think it worked out 62quid including v.a.t they didnt have it in stock but only took a couple of days also it was metal so im assuming it will be stronger as my last one had snapped within the water pipe
vw heritage could also ordeer thesee bbut weree asking 115 +vat thanks lads hope this helps
