When to do your cambelt? Intervals
(In Topic #201686)
With normal use it would be 60-80k but I changed my at 50k because it was the original so I was looking at the age of it more than the mileage.
So depends on how it looks and how you feel about it.
But if you do change it make sure you do the water pump at the same time if not already done.
Many people forget or don't realise that they should change the pump at the same time!
Regards Volkswarren
This was my thinking to do the water pump and just the ease of doing the belt whilst I'm there makes sense to me even if it's prematureGolf Cabrio said
Tricky one if it's only done 7k.
the engines staying in but just that whole assembly is stripped so just a thought for peace of mind really as I'd only end up doing it next winter anyway, do you change the tensioner or leave well alone if there's no issue with the one fitted?volkswarren said
If the engine is out there is no simpler time to change it, if you leave the engine in id probably wait another two years.
Regards Volkswarren
Have you took the cover off yet and checked the seals?
okay cheers for thatvolkswarren said
Change belt and tensioner, it's as likely to fail as a belt.
This is my thinking, I've only got the top timing cover off as one of the crank pulley bolts is rounded and need to bring home some proper tools from work to sort it, the engine is pretty oily and grubby all round from the years I'm going to do the rocker cover and sump gaskets and clean everything up and go from theremark1gls said
For the price of a cam belt and tensioner I would change it while other stuff is out of the way.
