What rad on carb'd KR?
(In Topic #107394)
Mk2 rad isn't giving me alot of room for my carb filters once the coolant hose is on! Some lad on e38 mentioned a corsa rad? Any help/part numbers would be greatly received!
Cheers,
Tom.
Cheers,
Tom.
Have a look at the corsa rads possibly do a search on club gti as i know they are not as high but are a bit wider and think the hose connections etc all line up !!
G60
Cheers 8)
I have a 1.5 Corsa TD radiator (as in, not fitted to a car). One of the hose connections is on the other side so you'd need different radiator hose(s) but it offers more options. Also, it is less tall than most other radiators, so its possible to mount it further forwards than the stock radiator position, underneath the front slam panel. You might also need to fabricate supports at the top and bottom, tho I think it uses a similar arrangement to the Mk1 Golf at the bottom and might just slot into the pre-existing holes.
