What rad on carb'd KR?
(In Topic #107394)
Cheers,
Tom.
G60
andy77 said
Have a look at the corsa rads possibly do a search on club gti as i know they are not as high but are a bit wider and think the hose connections etc all line up !!
I have a 1.5 Corsa TD radiator (as in, not fitted to a car). One of the hose connections is on the other side so you'd need different radiator hose(s) but it offers more options. Also, it is less tall than most other radiators, so its possible to mount it further forwards than the stock radiator position, underneath the front slam panel. You might also need to fabricate supports at the top and bottom, tho I think it uses a similar arrangement to the Mk1 Golf at the bottom and might just slot into the pre-existing holes.
