What next?
(In Topic #76771)
What next?
It has been dyno'd at 105bhp with 102 lb of torque. my mate has a 175 bhp clio and has challenged me to a drag. now me being a vw boy i dont want to let the team down and get completly embarrased. i have 4 months to 'refine' my car so what next? cams, balanced and lightened bottom end, gas flowed head? any suggestions other than Nitrous are welcome. but i need to know where to put the work first. i want to wipe the smile from his face. THe cars stripped with buckets and lowered on coilovers on 8x14s. i know i can never make 175 but just to get with in a second or 2 of his time would be nice.
Thanks Dan
Rebuilding Again…
The ratio goes…….
To go twice as fast you need eight times the power
You can work it out from that how much power you need to gain a few seconds on a 16second quarter etc
What power
Rebuilding Again…
Early 1.8 DXs had g/b codes 7G, with very slightly different ratios than later Campaign 9As.
Hows that for VW anorakium?
Rebuilding Again…
I found out today that his Clio is 150 bhp not 175!!!!
What sort of power can you get from a 1.6 on twin carbs??
Rebuilding Again…
PhillTMK1GTI said
Gear ratio site might be of some help, not every box code is there though (020 isn't for example)
020 refers to the gearbox type (020 = a rod-change 5-speed), whereas codes like 9A & 7G refer to the gearbox model (ie: the exact ratio-set for each car body/engine/sales market combination)
PS: to be sure of wiping the floor with the Clio, fit the 1.8T engine 8)
