What engine can be put in my Clipper?
(In Topic #88892)
My '92 Clipper needs a new engine. The carburettor has flooded the engine with oil and basically ruined it (thats what a garage in Caerphilly told me) so I need to replace the engine.
Would this be suitable:
http://cgi.ebay.co.uk/VW-GOLF-MK1-GTI-1-8-ENGINE-FROM-RUNNING-CAR-80K-MILES_W0QQitemZ110146042631QQihZ001QQcategoryZ9889QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Alternatively, what other engines could I put in it? How much money is it likely to cost? (I just want my car to run again, so nothing fancy!)
Thanks!
Never rub another man's rhubarb…
The pierburg 2e2 carbs are notorious for playing up and causing allsorts of starting and running problems but the basic engine is usually OK.
The ebay engine is an injected version so won't fit without lots of other bits and extra work. Also without hearing and seeing it running it might more fkd than yours :dontknow:
If the original is U/S then find a late 80s/early 90s MK11 Golf/Jetta or Scirocco with a 1.8 carb engine, lots in scrapyards and a direct replacement.
The garage have basically said that the carburettor keeps flooding the engine with oil, which has washed the balls (bores?) out of the engine. They say the engine is pretty much f**ked and I should scrap the car (to them for ?100!).
:cry:
you aint said what miles the car has done or what nick it was in before it died…. was it burning oil?
that engine u posted would be no good for your car unless you wanna get stuck in like.
sounds like your piston rings are borked (from a rough guess) is it blowing oil up into carb and not starting?.
try and find a mk2 golf 1.8 driver, gl engine, if you are stuck get a 1.6 driver/cl engine cheap and plentiful. if u can go look at at engine thats running that helps loads. wont be much more than 100 quid for a good engine.
your cars worth a lot more than 100 quid mate, go to another garage.
There were times when I'd be driving on the motorway and there'd suddenly be a drop in power, so I'd have to drop down a couple of gears, but that only happened maybe 3 times and it would always been fine after a few minutes.
Any ideas?
<img src="http://i45.photobucket.com/albums/f78/mcflyrips/100_0773.jpg">
B?@*&#?S
I no longer have the Mk1!! I now whizz round in a Black 1990 3dr Mk2 GTi 8v but the roof doesn't fold back when the sun shines
pete
Thanks.
