what can it be
(In Topic #80268)
Social Media Manager
what can it be
what can be the problem :dontknow:
DO I NEED A NEW FUEL TANK? :dontknow:
please help uch:
Can you tell if its dirt or rust in the filter? You would only get a lot of rust coming through to the filter if something was rusting and collapsing into the fuel system i.e a filler neck. When you flushed the tank could you see sound metal inside it? Possible the tank is rusting, but not sure you would get a lot of debris and likely you would get fuel leaks :dontknow:
1983 1100 C
1983 1100 C
1983 1100 C
1983 1100 C
markwon said
Are you sure there was absolutley no rust left in the bottom of the tank after you flushed it? Do you have an inspection cover under the rear seat to look down into the tank? Worth a look with a torch.
when i cleaned the tank the inside looked well clean and silver, there must be rust in some corner that i cant see, :dontknow:
where can i get a brand new tank from?
muttley racing ftmfw
