Weber carb leaking
(In Topic #127737)
Weber carb leaking
Seems to coming from a cover containing a diaphragm on the front of the carb,held in place with 4 screws,and also another cover on the side,held on with 3 screws.
So-would using a repair/service kit to replace the seals fix this? Or as i suspect petrol shold not enter these areas and something more serious has gone wrong and i need a new carb.
I took the carb off today and used an airline and carb cleaner on everthing i could find,refitted the above mentioned cover as tight as i dare,fitted it all back on the car and it still leaks
You can see where petrol has been collecting corroding the area at the bottom of the diaphragm
Weber stockist will be able to supply you with one of these and/or a complete overhaul kit to make it run like new.
So got myself a new weber delivered today,swapped everthing over,no more leaks
Re: Weber carb leaking
woodpm said
I have managed to route all the vacuum hoses in the correct way using the great guide on here and running improved a lot
what guide is this of which you speak! i need this guide, please help!
apologies for jumping on this thread
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=58393
if any one can do a new one with images lots of ppl will be graitfull xx
