Weber 36tlp (1B3 replacement) mixture adjustment
(In Topic #139510)
Car is misfiring on throttle change, but runs fine at idle, constant throttle and under full throttle.
The plugs are fairly black.
So I need to know if screwing out (anti-clockwise) adds less or more air at idle?
Will take it to be done properly when I get a chance (Only use it rarely so no matter if it's rough and ready!)
Cheers!
I'd clean the plugs first, then go 1/2 a turn at a time to get it ball-park correct.
I may be stating the obvious, but the mixture screw is covered by a "tamper proof" plug - it's the idle speed screw that's the big, obvious one.
