Weber 36 TLP Help.
(In Topic #154800)
I understand that the 36tlp is the upgrade for the pierburg 1b3. Car is a 1982 cabrio 1.5gl
Bit of a newb question, but its is as simple as removing the pierburg off the existing manifold, and replacing it with the weber without making any alterations?
It really is as simple as removing the Pierburg and replacing it with the Weber - you'll need to connect the fuel line to the carb, and the throttle cable.
TLP has a manual choke so you need to run the cable through and connect both ends - and remember the waterchoke on your pierburg? you need to either connect those two hoses together, or to the coolannt connections atthe base of the carb - I suffered from icing quite badly until I put coolant through the carb and its been fine ever since!
1 hour tops.
Take it easy ; )
Take it easy ; )
