webber rubber mounting
(In Topic #183148)
http://www.ebay.co.uk/itm/MK1-CADDY-Carb-flange-Pierburg-Golf-Mk1-2-1-6-1-8-Carb-82-/390758623777?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5afb076a21
I've seen someone make one out of alloy but not sure how they got on with the heat from the manifold going up into the carb so don't see why you could not make one out of plastic?
Cheers for reply ...I have changed it before and just thought it might be better to make one just wondered about any pit falls of it been fixed solidmark1gls said
Carb flange is what you need to be looking for, you can buy replacement, one from ebay here, GSF also sell them and might be cheaper as do VW heritage.
Should be no issue being solid. Most other engines use solid mounted carbs.
Get a rubber one from GSF etc and then make sure it is not taking the weight of the box, then it'll go on and on
