exhaust banging under car
(In Topic #194760)
If while driving I'm just feathering the throttle the exhaust bangs the underside of the car and I can feel it at my feet while the car kangaroos. If I give it a little push on the throttle it goes away. It's always been like this since iv had it so just put it down to the cams and other engine mods but recently seems to be doing it more and starting it is taking a little longer to get it going and hold revs. What's your thoughts guys rubjonny ?
It's all shits and giggles until someone giggles and shits
paul_c said
How was it remapped?
To be honest I don't fully know as was done before I got it but all aimed at the top end.
as for running issues what engine managment are you using? the abf ecu isnt a fan of lumpy cams it messes up the vacuum signal to the MAP
ABF Engine 190bhp.
Fully rebuilt top end and bottom end. Lightened and balanced crank. rods. pistons. flywheel etc. upgraded valve springs. black diamond uprated clutch and bearing. . Newman high lift camshafts & adjustable vernier pulley. remapped. all set up on the dyno by TSR Performance in Somerset. K&N 57i kit. . full straight through Milltek stainless exhaust system. gas flowed cylinder head. ported and polished inlet manifold and throttle body.
The other thing it could be is a loss of compression, that will make starting more troublesome.
rubjonny said
what engine management has it got? as i say lumpy cams can throw off the abf map sensor
I really don't know. If I take a picture would that help?
not sure if a filter would help, but it certainly wouldnty hurt
