Unknown cable coming from inside car to under bonnet
(In Topic #162909)
I've just noticed that it's sitting there doing nothing!
It looks like a bonnet pull but the bonnet pull already works perfectly.
I've circled where it comes into the engine bay
Hope that helps
I've been getting no heat out my blowers - this will be why!!
So, I need one of these?
http://www.vwheritage.com/vw_spares_Heater-valve-T25-Golf-Mk1-Cabrio-Scirocco-171819809E_act_shop.product_pID_200306_lang_EN_country_GB.htm
If the copper pipe someone has fitted is letting water through you should be getting hot air in the car as the valve stops water getting past in to the cabin.
Just to check, you only get hot air from the vents on top of the dash and 2 small vents at the side or the foot wells, you only get cold air from the main side vents you can open.
Cheaper one here as VW heritage are always expensive…..
http://www.ebay.co.uk/itm/HEATER-VALVE-NEW-FOR-VW-CADDY-SCIROCCO-GOLF-MK1-CABRIOLET-TRANSPORTER-T25-LT-80-/360694665673?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item53fb13d1c9
Some others on ebay as well, GSF sell them, £8.28.
