Trouble Starting in the morning
(In Topic #106368)
I am having trouble starting in the morning. I turn the car over and it will try to start once, if I am quick enough on the throttle then it starts. But if I miss it then it wont start and I have to bump start it. I dont think there is a problem with the battery.
I have a 2litre 16v engine from a corrado in it. I have changed the spark plugs and leads, I was going to change the distributor and rotor arm but these look like they have bee modified from the original.
Could it be the coil not producing a big enoguh spark?
I will try to post some pictures of the dizzy later, but does anyone have any ideas?
Thanks,
Ian
I am thinking that the spark isn't strong enough so it could be a bad earth.
Anyone else have any ideas?
I didn't do the conversion.. the previous owner did. Could you give me some more details on what you mean.. I only have limited knowledge when it comes to this.
Cheers,
Ian
urbantricker said
Hi Paul,
Cheers,
Ian
Well, 5th injector is somewhere at the front and on the left of a 16V manifold, its an electric injector and it will have a fuel line and an 2 pin electrical connection.
TTS on a 16V is located on the left side of the block, just above the bellhousing. There's a couple of other sensors and connectors here too, so its a case of looking at each connector's wiring, and size of the sensor (TTS is a little larger than a coolant temp sensor) to see if one's there. Also it has a 2 pin connector, unsure what the other sensors in that area have but they're sometimes just 1 connector.
Both devices have red/black and green/white wires for the 2 connections.
I suppose you could remove the 5th injector to see if it 'test fires' when the starter is turned and the engine is cold. It will come on for a shorter time, or not at all, when the engine is warm/hot. It only comes on when the starter is turning, ie circuit 50 is energised (which I think, is the red/black wire).
Thanks for all the info. I will hopefully have a chance to look at this at lunch time.
I will post back on here with any findings!
Ian
