Temperature too hot?
(In Topic #139306)
just got a Mk1, cabby 1.8.
Quick question, what sort of temperature should I expect it to run at in traffic and around town?
At the moment in traffic it often creeps up to 3/4 and around town it's a bit over half, I've had problems with pipes bursting and what not, so i've replaced the fan switch so the fan is working fine, i'm not sure but I THINK the bottom rad hose never warms up as it should so I might need a new thermostat. will check tonight, but could that be the cause of the high temperatures? ( if they're high!)
I haven't noticed any steam from the exhaust and it seems to be keeping all the coolant on board at the moment. Is there any other things i can look for, short of doing a compression test - which i don't have the kit for ?
Thank you,
So providing your not getting any other signs of over heating just ensure the basics are done correctly.
can clean/flush out the sytem if you wish.
Always use correct coolent mixture.
If you replace mixture ensure heater matrix fuly opened and run with expansion bottle cap off for a while to ensure no air locks.
Any signs of leaks can normally be spotted by white buildup.
youve replaced the sensor that turns on the fan and checked its working.
can change the thermostat for that extra comfort factor.
1988 1.8 carb Golf Clipper
It's good to know the car's happy enough a bit hotter, and reassuring that it's an accurate representation rather than the car manufacturer mollycoddling my worried mind
After a good flush, and new 50/50 coolant, mine went from running just below 3/4 (fan kicking in after just a couple of minutes in traffic) to running at just over 1/2 on the gauge.
