Strut brace 1.8 carb engine
(In Topic #129099)
Well i want to buy an upper front strut brace but need to know will it clear my carb with the k&n on it ?
Thanks in advance
G
You could look for a really cheap one and jump in, prob best to avoid fancy alloy ones tho.
I have one on my clipper, bur have a totally different carb set up.
Projekt Frustration :
White 1991 Clipper. Lowered over polished zender rims, Single 40 dellorto on lynx manifold, kent cam, full stainless 'zorst / manifold, powerflex bushed and braced. Not the fastest car, but sounds super nice!
Still going after 12 years… never said it was a quick fix! Time is not my friend.
i will buy a cheap one and try fingers crossed
This is only issue i noticed over teh years, braces made for gti's etc or used on blocks wiht twin weber for example so nothing blocking the route of brace.
I am surprised no one as yet done a brace for the bigger block mk1 & 2 golfs as they would sell.
Something i've always wanted on both my cars, i have lower and rears in both at moment
Peddersgolf said
Flat pancake style YES, standard pancake or original airbox NO fellla.
design below works well with a standard big block engine, in my case 1.8 with standard carb. only mod I havce made is to shorten one of the air filter spring clips just to stop it making contact, but that could just be engine mounts have a little more play than new.
1988 1.8 carb Golf Clipper
Thanks again
Glenn
I should have made it more clear, but when you have a weber fitted the carb will sit higher than what it does with original carb due to adaptor plate etc thus i don't have a brace on the front on both my golfs.
If someone could make one for weber owners would be great, this is downfall only done as for original setup
Pete
Freeman: The basic principle of a stut brace it to prevent flex and movement in the suspension/body. Front can have both upper brace ( between suspension turrets ) and lower brace ( between the wishbones ). I have both. With the car being a cab, it's lost some of its structure, you can hear the difference if you take to upper brace off my car.
Your quite right coilovers, strutbraces etc designed to stiffen and therefore can lead to a harsher ride for uneven surfaces. Its just a preference thing as to what you consider the best balence is.
Thanks again
G
Pete
djheap22 said
if its crashy on bumps/pot holes first place to check is the condition of the top mounts. Post a pic and people will be able to tell you if they are in need of replacement.
Not so sure crashing over bumps will be down to top mounts, more like worn out dampers or a broken spring. most cars are now over 20 years old now, so most of the surpension components will be past the sell by date!
I'd replace the top mounts if you are doing anything related to the front end suspension, well worth doing, I found my steering lighter with the new mounts on, plus it made changing the front struts easier, built up the new ones, then just swopped the old ones out as a complete unit
Stutbraces on thier own will not make a massive difference and wouldn't really effect the ride of a standard car, just stop it flexing. Ride quality with coilies depends on what you choose to run. Also the ride height will be an issue, if you are running low then you don't want much travel in the suspension, so it will be stiff, it all down to personal taste.
1979 S1 MK1 Golf L FOR SALE! http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=101471
1970 VW Beetle 1600 Twin 34 ICT\'s - Betty
1973 Marathon Beetle - The Moll\'s
