specs of my engine
specs of my engine
My car is vw golf mk1 1800 8V and i want to find the specs of my engine, i think its from a mk2 golf and i cant find anything
my head code is 026103373 F αnd on the right is written the " Η " , can you tell anything about my engine, hp? carb or injection?
thank you
The engine code is just below the spark plug in cylinder 3, it starts with 2 letters and that tells you what engine you have. Is yours carb or fuel injection?
You can also check the engine code against the one on the log book to see if it matches.
Why do think it come out of a Mk2 golf? The same engines was used in the early Mk2 golfs.
I can't help with the numbers on the head but try googling it and it might give you the year it was made but not sure.
just had a look and found this site
http://www.clubgti.com/showthread.php?220746-4-cylinder-engine-block-amp-head-cast-part-nos
Last edit: by mark1gls
