smokey engine
(In Topic #77657)
smokey engine
Generaly
Blue- OIL
White- Water
Black- Over Fueling
TT
black!
Have you actually taken it on long run or just started it up and let idle whilst parked up?
Hi thanks for the replies
Not sure about earlier carbs, but GTIs setup properly def benefit from 97/98 octane Shell Optimax type stuff. Also think later 1.8 carbs are better on it aswell?
Never had an auto but would guess that when you put it in drive the torque converter causes some drag and slows the engine, so sounds like its working as it should.
I?ve had experience of petrol ?going off? if left for a while. This was in a 1966 Beetle I bought and spent ages trying to get it to run right, changed points, condenser, reset gap, new HT leads etc etc. Eventually had to fill it up and the fresh petrol made it run like a dream.
Thanks for the advice
If its still running rough get someone who knows what they are doing to adjust timeing and CO.
Many thanks
serviced it
(also had to change rocker cover gasket) was leaking
