Single 40 DCOE Weber - 1991 Golf Clipper!
(In Topic #141070)
Ok guys…hopefully a simple question…VACUUM ADVANCE TUBE!
I am changing the head on my 1800cc Clipper/carb from the standard head to a GTi head.
I am of course doing the usual blanking of the injector holes etc etc…
My concerns are simple:
I will be throwing the standard airbox/air filter arrangement, as the DCOE has trumpets and sock type filters.
However, the airbox has the vacuum advance pipe going into it, where do I now put it?
If anyone else has done a similar conversion, and has any other tips/pitfalls, i'm all ears!!
Thanks guys
Definately the Vacuum advance pipe to the dizzy…the very small bore tube.
Currently plumbed into the airbox..
Just want to be sure where to plumb it, as the airbox is redundant with the DCOE weber.
Thanks..
If I fit a single 40 DCOE sidedraught carb on a Lynx manifold, I cannot use the standard air box/filter assy, as its designed to fit a downdraught carb.
Therefore I have to remove it and basically throw it away.
40 DCOE has trumpets and Pipercross foam filter socks that are cable tied over the trumpets.
That's all cool and easy.
However….
It leaves the Vacuum advance pipe from the dizzy that was previously attached by a little push on pipe to the air filter box/assy, with nowhere to go.
So I just need to know where to attach the vacuum advance pipe so the dizzy works properly?
Thanks for your help.
so, put it where it belongs, problem solved
