She's a Moody Girl In The Winter!
(In Topic #94768)
My poor girl is starting to cause me real distress! Don't get me wrong I don't like the winter either, but this is becoming ridiculous!
She appears to have developed a habit of cutting out. It?s strange because I'll be driving along then it will stutter, and if I put my foot on the clutch it completely stalls. If I sit stationary, it will idle all day, its only when I try to move forward that the problem begins. I've broke down like this a few times, where I can restart the engine and it always starts but eventually the battery dies. If I then get a jump, I normally can drive the car home again without issue! I've been to two mechanics and this is becoming an expensive and aggravating issue. :cry:
It is a suspected fuel starvation issue, so they have changed the fuel pump, inline fuel filter and also found that the distributer cap was showing burning so that got replaced.
It?s got so bad that I've had to resort to using my friends Corsa, which although is not to most tastes, it gets me to work and back a lot more than my golf will right now!
Its a Clipper Karmann 91 Cabby with a 32/34 Webber Carb, If anyone has any advice I would really appreciate it, I've got it booked in for work on Wednesday, so would like some suggestions when the mechanic is clueless! :dontknow:
Cheers,
Dave
wires. They are tiny and bend about as the advance and retard moves on throttle changes thus cutting of the ignition. A unit from any old sirocco/golf/jetta of the same era will do. (not the whole dist, just the sensor.
Keep smiling J.
Beetle restoration. Cabrio GTi (black and shiny). Golf driver.
16v MK2. (Oak green) Now on a Clipper (to keep). Audi A8 4.2 Quattro sport and a BMW R65 bike.
Thanks for your quick response, I will take both ideas forward to the mechanic. He's a VW specialist (or so I've heard) so I hope he'll be able to resolve.
It's funny, I really do love driving my golf, even tollerating the abuse from my colleagues with their brand new Honda's and BMW's…but its times when they can't get you to your work that the tempers really get frayed and you wonder if its worth it!
Cheers,
Dave
ive changed.. dizzy, and the ignition stabalizer module (on the bulk head) plugs and leads ( just because they aint been changed for a while) so far so good, as before it would start missfireing and get worse till i turned it off or it cut out, when left 2-3 minutes it would start up and run fine. all this was at operating temperature at motorway speeds, common sence points to the hall sensor/ mechanical advance not a bit of rust in the tank,
She used to misfire, but that was resolved with the distributor cap change.
I went round a mates (who is a mechanic) at the weekend, he was speaking to a colleague about the issues I've been having. He said that the fuel reservoir has been known to cause issues by introducing rust into the fuel lines. To test he put a clamp on the fuel line from the reservoir and asked me to give it a run for a few days.
I gave her a good run yesterday and didn't experience the problems at all. In my head I felt she wasn't running as fast as normal but I got her up to 80 without any stuttering. Prior to the clamp I was lucky to get her past 35!
Do you guys think he could be on to something?
Cheers,
D
Jonamat said
Pete, Who said anything about it running on 2 or 3 ? J
my bad i was reading anothe post on anoother site and got replys mixed up, if it makes yopu all feel better i have traped my fingers in the kitchen draws and snorted chilli powder
