setting up a weber carb for 1.8
(In Topic #94622)
mk1 work in progress
as for setting up the mixture. turn the mixture screw in till the car is just hunting the out till it stops. then set your idle speed.
pul the dizzy cap off and have a look under the rotor arm if you have a set of points its non electric or points ignition if you dont you have breakerless ignition. (hint the points are under the white cover) if it's on points these need replacing. change the condenser while your at it. check the oil breather pipe isn't blocked and check your timing. then set the carb up.
main jets primary:117 secondary:127
air corrector jet: primary:145 secondary:200
emulsion tubes: primary:f30 secondary:f33
idle jets: primary:55 secondary:60
pump jet:45
needle valve:175
take the dizzy cap off.
remove the rotor arm (make sure to put it back the same way it should only fit one way)
lift off the dust cover
you may have to remove the bearing plate but that depends on which dizzy you have.
now you can see the points.
on unplug the wire you can see that has a spade conector on it.
undo the screw on the side of the dizzy that holds the condensor on and remove.
easy test is
remove dizzy cap so you can access the points.
stick the car in gear and rock the car till the points are closed (touching)
turn on the ignition and seperate the points with a screwdriver on the lever arm.
if you get a strong blue spark the condensor is dead. a weak spark is perfectly normal.
hope that helps. pete
