Running rich how to fix
(In Topic #124577)
have a slight issue my 1989 auto cabby is running rich , you can smell the unburnt fuel and when you turn it off, it runs on and then backfires.
Is this a job for a specialist? Or could I fix my knoweledge on cars is ok.
Any help would be great
Thanks guys and girls
Skye
if you want to sort out the mixture grab yourself a colourtune from a machine mart as if you lean it off too much you'll get detonation and that can be very bad news
a colourtune will set ya back about 25 quid and is a life saver
you can only adjust the idol mix though, the throttle mix isnt adjustable without re-jetting so i would assume the rich smell is when your car is on tick over?
also wobble the carb a little cos they sit on a rubber gasket which can tear with age and if this has tore it can let air out making your car run rich
just a few bits for yo to try bearing in mind im only using guess work as i have a small block
hope some of it helps any way
booze and boredom, the greatest mix
i thought the mix screw is only to adjust the idol mixture, once the throttle opens it moves from the idol jet to the main jet,
i was under the impression the main mix cannot be adjusted and is set by the main jet…
this may be on the solex carbs tho..
Thanks guys
the running on could be a symptom of runnign rich if its been doing it for a while, you'll end up with a lot of carbon buildup which causes hot spots in the cylinder and run on. my old mk2 did this because the autochoke had been knackered for years hence loads of carbon buildup. fixed the carb then did the water trick to clean all the carbon out the cylinders and it never did it again.
if its the 2e2 then there could be several reasons why its running rich, fiddling with the mixture screw could just work around the issue and cause problems elsewhere. if you feel like it have a read thru my 2e2 faq post, but if you arnt mechanically minded it might be time to get a webber replacement, or ask to see if anyone is local to you who can help! might be worth printing out the guide and taking it to your local freindly garage otherwise, but they might not be inclined to bother with it ans just change the carby instead.
