Rough running 1.5, Weber - need advice...
(In Topic #121726)
She runs fine on the choke and once at temperature idles at 900-1000 with no problems at all. When you push the accelerator really gently, she lifts revs normally. However when you push the accelerator normally, as you would when pulling away, she cuts revs to the point of almost stalling before it cuts in and drives off.
Additional to this, when going up steep inclines she need masses of revs or loses all power, stalls. Then you need a combo of full choke and serious revs to get her going again. Or if you can push her round so she's facing down again! Confused…
So far I've:
changed the inline filter, the old one had some crud in, but not a lot
removed, stripped and fully cleaned the carb - which was okay
replaced points, plugs, condenser
That's as far as my knowledge goes, so I've got her booked into my local friendly mechanic next week (he's not a VW/Goof specialist though… and wanted to give him some pointers on where to look…even the simplest advice would be helpful.
Thanks in advance…or if any Londoners fancied coming round to have a look I can pay in tea and beer
'83 Golf 1.5 GX - weekender - in pics: 1983 Mk 1 Golf GX - a set on Flickr
'88 T25 camper 2.1 - in pics: Gina the van's renovation - a set on Flickr
carb
mk3 colour concept sadly made way 4 the mighty 1982 mk1 cabbie karmann
- Piece of gasket poking into throttle body
- Corrosion in accelerator pump/jet
- Snapped a bolt, no wait that was my fault.. *ahem*
- Incorrectly set idle screw
- Damage/slightly split brake servo hose doodad (from manifold)
- Badly gapped points
- And in the end I advanced the timing slightly, about 2-3mm.
oh yeah and the choke was incorrectly functioning due to it being bent, also the accelerator cable return spring was applying pressure at fully closed throttle, which was unnecersery.
~Madferret
Mk1 1457cc 5door GX '83
Check your filler neck by removing cap, look through and you should see holes just around where the pipe bends downwards and check tank by removing sender from underneath rear bench as i feeling your filter on end of sender is blocking as rust moving about
99% sure your problem bud
All the carb gaskets etc looked okay, looked at timing and points gap too, all seemed okay.
@ Pedders - I heard that off another forum too actually - but couldn't get the sender unit off. Is there a knack to it?
Filler neck itself is rust-free, but it looks fairly new, so I suspect it's been replaced in the last few years…
and if it is rust inside, then what's the cure - new tank?
To remove rust from tank, get a magnet on a piece of wire or the like and gently lower and move it about on the bottom of tank.
Here's how to get into tank
The Mk1 Golf Owners Club
I foresee myself driving (roughly) round and round my block to run her out of the £5 petrol I put in last week before attempting this though!
Pete
Can someone tell me (or show me a pic) of where this is?Peddersgolf said
has the vapour seprator at front of block been replaced as that will collect the rust particals and cause blockages, a
Have completely stripped carb, cleaned it. Nee points, plugs, fuel filter. Taken fuel sender unit out and cleaned filter on the end of it, looked around in tank, didn;t look too bad, dragged a magnet around inside. Some small particles of rust yep but nothing big.
Am at the end of my tether now, haven't had her running properly since December :cry:
I'm prepared to pay someone to sort this, but the mechanic I took it to just said 'she's 20 years old, of course it'll run rough' Then i told him the engine's only got 2,000 mile son it. Eedjit. Does anyone know a SW London golf-friendly place/person?
Here is Part your wanting to see
also gotta check out the compression i guess….and someone suggested the coil, but that seems less likely to me.
VOTE FOR MY CAR ON COTM
92 clipper, chrysler red, tt interior, 16" splits, slammed!
