rocker gasket
(In Topic #97529)
rocker gasket
It should come away easily now, in fact I'm not sure if you have to actually remove the outer cover, it's probably OK just to unclip it and move it out of the way.
Chris
1990 Scirocco GTII
2001 Jag S Type 4.0V8
1990 Scirocco GTII
2 peices is easy. there is a allan head screw about 8 inchs down the cover that needs to be removed then lift it off easy. dont have to touch the cam belt or adjust anything but while you've got it off best check your cam belt.
post some pics sure we can help.
When you remove it put back in reverse, you will see that the lower part of cover has a groove in order the cover to sit flush with the lower cover.Don't worry about cambelt, you wont do anything atall to change it, but good chance to view it, but also if it has not had a change in past 30-40,000 mile, get it changed.
Any problems or pics need, let us know
Pete :wink:
PLONKER
Glad it's sorted fella, mk1 motoring carries on
Pete :wink:
ho hum we've all been there at some point or other.
