Rocker cover leaking
(In Topic #110854)
Thanks Sean
CAMPAIGN-HELIOS BLUE-POSSIBLY SEEN IT ON CHRIS BARRIES(RIMMER IN RED DWARF) MASSIVE SPEED PROGRAMME?!!!
i replaced my rocker cover gasket recently and noticed as i removed one of the nuts, that the stud it came off was loose in the head.
not sure if this was like this before i undid the nut or not?!? you would think that it would all tighten up as you did up the nut over the rocker cover.
but i made sure i tightened it back into the head before refitting the gasket and rocker cover.
then i checked all the others. might be worth checking yours…
ash
Thanks Cero,Ive taken your advice and it seems to have done the trick…see what happens when I take it for a run
Thanks everyone
Leak
Would the gasket sealer also stop this from leaking please?
Coggs
Re: Leak
Brfc1883 said
Mine is leaking from the side of rocker cover after I chnaged the head gasket as well! The oil is spraying onto the Cam belt and spraying all over the bonnet and drive shaft.
Coggs
I think you ought to consider changing your cambelt if it's contaminated with oil. You don't want that slipping off !
DubPartz
