Revs drop and cuts out *urgentish*
(In Topic #108243)
Hey dudes, ive got a mk1 1.5 GL and it started playing up when i was driving along the revs would drop right off and the car cut out.
If i turned the key off and on again it would be ok, or if not, i could pull over, leave it a couple of mins and it would fire up.
I replaced the
-coil
-leads
-points
-condensor
-rotor arm
-dizzy cap
-plugs
since then it had been pretty much ok until today
now when i try to fire it up the revs drop straight off and wont idle at all.
the only thing i can link to the problem if it helps to get a solution is that the green hazzard/indicator flasher LED is on constant when i indicate or put the hazzards on, even if i replace the hazzard relay.
if anyone has ANY ideas or suggestions it would be muchos appreciated as its my daily!
cheeeeers
I replaced the
-coil
-leads
-points
-condensor
-rotor arm
-dizzy cap
-plugs
cheeeeers
owns:
mk1 jetta 1983 blue
1966 beetle on hydros
1959 lowlight karmann ghia
mk1 jetta 1983 blue
sorry duder, found the other section right after i posted, and then i got confused and greedy cos it was urgentish, and i would have got away with it if it wasnt for those pesky kids
point taken tho dude
owns:
mk1 jetta 1983 blue
mk1 jetta 1983 blue
