radiators for a cabby
Does any one know which radiator i need for a mk1 clipper with a standard 1.8 8v engine with a pietsburg carb.not sure of the spelling, seen loads on ebay but cant match the codes up. 05594301
Was all that was on it and its roughly 52x32x3cm,kinda dropped it when the garage was a mess and now ive refitted it its leaks out from where the brackets fix to the plastic.any help would be great.cheers dom
mk1 clipper
mk4 gt tdi
check www.vwheritage.com
Cheers rang some one of ebay was only 40 quid hope it works lol
mk1 clipper
mk4 gt tdi
tbh I wouldnt buy from ebay (cheap crap) I spent £90 on a genuine one.
try eurocarparts they are £51 less the club discount which takes it toabout £35, now if you are not a member then this would equal your membership
Haydn
Regional Host South Wales
Damit already brought the one off ebay.that sounds a better idea
mk1 clipper
mk4 gt tdi
same size as a 1.8 8v gti rad just for future reference :)
Clipper has a smaller rad than gti.
hmm looks like its only mk2s that this is the case then!
Yea, tho I have had mk2 16vs with the small rad, both early cars, also 1991 1.8 driver had small rad.
yah mk2 16v use 1.6 size rad, but double core. 1.8 carby mk2 should all have the 525mm rad, maybe it was swapped or it had an engine conversion?
I would agree but the 91 mk2 was a 1 owner car so god knows.
