problems
(In Topic #79775)
problems
window wipers do not work
indicators do not flash or come on
temp gauge does not work
horn does not work
any help on what i should be looking out for what relays are ment to be there if anyone has labeled pics of the fuse box area would be great need help with this car i think lol
a haynes manual should tell you what each fuse is.
check all connections are right and clean.
check that the horn does actually work (just connect it straight to battery quickly)
check that the senders are clean and in contact properly.
more than likely that they are all similar electrical problems…
Rgds, Andrew
hi
look here, should help you out fella
http://www.vintagewatercooleds.com/tech/Techtips/Timbotechnotes/fuses/fuses.htm
bye_all_c_ya said
thanks mate i take it a 1982 ( y) will be the same as a 83? as in wiring
exactly the same.
they have special magical machines that can find the problem straight up, so they may be able to use one of those.
Maybe up to ?40 + VAT? :?
Hope this helps….
it may be cheaper going to an electrician of some sort.
Cheers, Andrew
