Power Drain
(In Topic #141947)
Power Drain
Since doing this i've noticed that my battery is going from fully charged to brown bread in less than a week. I thought the solution would have been as simple as downgrading again and removing the 12v cable from the boot.
Anyway, after removing the cable, the problem remained. I took a Voltmeter to the battery and tried to find out what was causing the drain and was also able to check the alternator to see if that was charging the battery as well as it should, I ended up replacing that with a refurbed unit because it just old and tired.
Problem persists…
I've learned to just put up with the problem by disconnecting the positive terminal on the battery after each journey but its annoying and I think its causing my alarm to have a personality disorder.
Can anyone suggest anything else? Has anyone had similar problems?
Ive tried to go over as much of the wiring as I can to check for arcing and loose connections but I cant find any, could it be a relay?
Thank you
Mat
No Rice...
Does it go on long enough trips to charge itself properly?
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
Having said that, if the problem is solved by disconnecting the battery, then the battery should have survived, although it might not achieve full capacity again if gone too flat and/or left too long, flat.
I'd be tempted to put an ammeter in series with one of the battery terminals then investigate any non-standard wiring and pull fuses individually, to see where the current drain is. Its possible the problem existed before your upgraded stereo wiring, but the battery has weakened so that its now an issue, where previously the battery coped with a small current drain.
If you can read this, thank a teacher,
If its in English, thank a soldier.
A soldier fights not because he hates whats in front of him, but because he loves whats behind him.
As far as I know, the alternators working ok as the voltage thats being pumped back into the battery from it is more than whats being drawn from the battery with everything connected and active (alarm, amp). My voltmeters getting on a bit but thats saying the battery is knocking out 12V's and its pretty new so I dont think its that, however when it went completely dead the first time I left it without charge for a week or two..
One thing i've noticed is another live wire from the battery, it looks pretty OEM (not bodged in) so I was thinking it was going to the dashboard to feed perm. live for hazard switch etc etc.. but when I had the dash out it was going into the back of the stereo, it looked like an effort from someone who knew what they were doing but I cant help but think this is the problem, need to do further investigations but will try all of the above.
Electrical problems are the worst, i'd rather it be a blown head =\
No Rice...
