Pierburg to be or not to be.....!
(In Topic #106596)
So replaced them
I have by ear adjusted the air screw on top of carb!
Now I have car starting fine even when -4 degrees, drives perfect ……. for about 10 minutes/ 6 miles it starts to splutter looses power and have to pull over! :cry:
I have to sit in the car with engine off for a couple of minutes.
Start the car up and off we go no problem very responsive :dontknow:
Could this be the flap warm/cold intake!
Where and how does the vaccum release when building up, as seems its not escaping !
:dontknow:
Any Ideas ?
pull the vacuum hose of the air intake flap. suck and see if you can make the flap move.
if not flap is ceased.
2 choices at this point.
remove the air intake flap and run a pipe straight from the inlet manifold to the pipe thats left. you can take it off in the summer and put it back in the winter.
fix the ceased flap so it works again.
i'd do the latter.
Although their does not seem to be a defined answer to prob, fingers crossed that this works
Pete :wink:
