pierburg or Weber??
(In Topic #127694)
pierburg or Weber??
Hopefully someone can help me, im needing a new carb and need to know if this is a pierburg or a weber?
http://i954.photobucket.com/albums/ae24/hack717/096.jpg
thanks in advance if you can help
Rosey
Schumacker Gol Gl 1.8 Turbo
Curitiba PR, Brazil !!!
~Madferret
Mk1 1457cc 5door GX '83
Getting a 2nd hand one youu will have to make sure the parts have been replaced which make the peirburg soetimes a funny bugger to sort out.
Weber on other hand there are no electronic componants, new £220 with manual choke which is perfect for the winter months.
I find from my experience of having new webers on any of my vw's they are a very good replacement, easy to adjust if needed, easy to repair.
Put it this way not had one go wrong on me yet.
Anyway good luck in your choice bud, i am sure others will give their reason and opinons of why they choose what they have to help you.
Back to question thou lol, that is a pierburg bud :wink:
I was presuming you were asking if you should replace it as a weber, or pierburg.
Looking at the pic now, it is a 2E2 pierburg, which if you follow the guide in this forum section should point to you not needing a new carb anyway
And yes the Weber is veru easy to adjust (and probably best for most), if you havent read the Haynes Carb manual :wink:
~Madferret
