pierburg 2e setup
(In Topic #208368)
help and love needed!
i bought a 2E few monthes ago and cant really tune it up properly.
before it was on a 1.8 caddy and now its on my 1.6 engine.
i was told by the seller to just put it and drive.
now:
how do i change the fuel mixer? (got black smoke and i thing its becuse it shooting too much fuel as 1.8 enigne)
air- got it
fuel-???
thanks!
pierburg 2e setup
Chortle
idle adjustment is complex, and shouldn't be messed with unless you're 100% positive it is needed. 9 times out of 10 its a carb issue causing bad idle rather than setup. same goes for the mixture screw, this and idle adjustment should be the very last thing you mess with after going thru my 2e2 guide top to bottom
rubjonny said
pic above is for 2e3 carb on smallblock, the 2e2 carb for big block differs. mixture justment screw is in the top under the big rubber bung in the airbox. iirc it works opposite to 'normal' mixture screws?
im so happy to "see" you here!
the screw your talking about isn't just the air?!? when i close it all the way down the carb still works….. does it mean it sucks air somwhere?
the big round thing on the back isnt responseble for the fuel amount?
look at the basics, make sure all the ignition components are tip top, look at the timing, make sure dizzy is good workign order and genuine bosch blah de blah
