Overheating problem with my Clipper
(In Topic #147342)
Cheers.
Fueler
the head gasket being the worst but don't be to hasty
do you get a good strong fluid return to the header tank, should just trickly out a bit on tick over then when you rev it should become a strong squirt?
next drain the coolent and flush the system with a hose, down every pipe and into every direction around the system, through the radiator as well
if this is all flowing nicely then you know the system hasn't got a blockage
next with the thermostat out, look up at the impeller on the pump, is it in tack? put you finger on it and turn the pulley does it spin or just slip
if it slips the impeller could not be turning thus not pumping around the system
check your thermostat in a pan on the stove, to make sure it opens fully
a few things to check first
