Opinions appreciated on starting engine after LONG layup.
(In Topic #104027)
Ran well up until that point I am told and have a stack of service recipts and parts recipts four inches deep up to that date.
All that has been stripped from it is an alternator and a fuel pump. I'm currently working on getting the body/suspension sorted.
I am torn between sticking on new fuel lines and changing all belts,filters and plugs and firing her up or dismantling teh engine to clean and replace all seals and gaskets before attempting to turn it over.
The main question, I guess, is will it blow up if I do the former?!!!
run it with the rad cap off so any air can escape
My project might just get it's MOT a few months earlier than expected now!
Non starting then could be petrol is dead as it does go off with time - bleed with turning engine over and fuel feed pipe to carb or fuel rail off (be careful where it spits fuel and do it in the open) if its carbed then water and condensation can build up in tank or carb bowl
Jon`s Dad
