Oil Filter Housing Wiring
(In Topic #137526)
Sorry for yet again another wiring issue. I have spent the afternoon trawling through hundreds of threads and posts looking for images of peoples engine bays lol before posting as this is an ongoing project which has been off the road a year.
Basically I've found a broken yellow and black wiring in my engine bay which I'm lead to believe is the oil pressure wire for the sensor on top of my oil filter housing. However there is a blue and black wire connected to the 1.8bar sensor. I'm now really confused as every time the engine revs past 2000rpm the pressure buzzer and light goes off. Could it be that the previous owner has confused the two wires?
I now need to make this a little more complicated as I have now taken off the original oil filter housing and replace it with the housing required to fit an oil cooler. I'm also wanting to fit VDO gauges which I have already got from and A4 (92) and want to make sure the wiring is right before I start messing on with the wiring for them.
Would it be any help if I supplied images of the wires and my oil filter housing?
Cheers Richard
I know the sensors are the right ones as I recently replaced them! Thanks for your help so far.
is the car a carby? if so it might be for that
One other question I have is do I 100% need a pressure sender to get the gauge to work or will the current sensor do the job?
you wont get your pressure gauge to work unless you fit a proper oil pressure sensor. VDO gauges run a dual pole sensor which replaces one of the existing sensors. you run 1 wire to the gauge, and the other connection is for the old pressure wire.
if its had the full carby engine loom fitted and the carb was changed to a webber this will probably explain the spare wire, the 2e2 carb the engine would originally come with has a couple of thermoswitches which are redundant when you fit a webber. this wire was probably for one of those switches
