nightmere removing inlet manifold!
(In Topic #82719)
i cant get at the last bolt due to the exhaust manifold being there, and i cant get at a few of the exhaust manifold bolts due to the inlet manifold being there also bolts are well tight and when theyve crackd of OUCHHHHHHH ive smackd my hand and cut it all up.
nothing like making it simple ay! :mrgreen:
so my question is, is there an easy way? am i being stupid and blind? (bearing in mind it is 7pm whilst im doing this so visability is abit poor. will crack on with it tomoz though in the daylight.
also theres a freen sphere thing not connected looks like a vacuum thingy do i need this or not, engine seems to have been running fine without it :dontknow:
chears
simon
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
I used a socket set with an allen key fitting on the end, and although they were tight they all came off in the end - even though having the engine in the car meant some serious contortionist activity
HTH
Rich
do you take the inlet manifold of first? then the exhaust manifold
or the exhaust manifold first then the inlet?
simon
chears mate
<a href="
Sometimes it helps to use a smaller size socket on the exhaust manifold nuts. I found that they rust smaller with age. Make sure your socket fits the nuts well before you attempt to undo otherwise you might just chew then nuts up and make the job nastier.
Get new nuts for reassembly, it'll make the job far easier next time. The replacement nuts from VW are now copper so they dont rust.
I'd replace any studs that come out when you undo the nuts too but leave any that stay in. If you try and remove studs that are really stuck hard in the head, you could end up snapping them off or chewing the threads up and not being able to remove them.
There are 6 bolts in total, 1 at either end of the whole thing (which I'm sure you'll have got off already) and then 4 others between the pipes which I struggled with at the time…
The one that gave me most grief was the bolt just to the right of the No. 2 cylinder inlet pipe, which is recessed in the gap between No. 2 and 3 pipes.
One tip which may come in handy is that if you already have the new inlet manifold gasket, you can see where the bolts ought to be by lining it up with the manifold while it's in place.
HTH
Rich
Another tip, soak the exhaust manifold nuts the night before your working on it wiht wd40, they come off with out a problem fella :wink:
nice one
simon
<a href="
Pete - is it better to remove the exhaust manifold to replace the core plugs? (Engine in situ - I've already taken the inlet manifold off) or can I do it from underneath without taking off the exhaust?Peddersgolf said
Remove inlet first, An easy tip is the way i get them out, use a small mirror so you can see them, job is simple then for you bud :wink:
But please before you remove the exhaust manifold, do at least one day of soaking the studs, i do 2 x in one day and again i do for the next day, but if you start early do 3 times, basically the more soaking the less chance of problems.
Get the exhaust nuts and tighten them very slightly to unlock them and you'll find they will come out easily, sometimes the whole stud comes out, but that is not a bad thing afterall it is better than snapping the stud in the block.
Buy some new studs and nuts (Copper) from gsf along with the gasket.
Once done put some copper grease or silicon grease covering the studs
Pete
Rather than round the nut or snap the stud I'll do it from underneath tomorrow.
