New Carburettor for 1.8 Clipper manual
(In Topic #129489)
Or common carb replacement is the weber 32/34dtml manual choke carb for approx £220
if i was local i would come have a look at it for you!
the good news tho is at least if webber your only option, there is a choke cable hole in the dash as standard, its behind that plastic square plate bolted to dash near the steering wheel
but yeah in your shoes i would rather get it fixed, the 2e2 is an excelent carb when it works.
the haynes carb manual is also very good, i have a small section of it for the 2e2 but its not 100% complete:
Google Sites: Sign-in
Just a case of removing inlet manifold bolts using a mirror and right tools inc a long exstentsion for the 2 inner bolts.
Remove old oring, clean the surface of any limescale etc so new one sits flush, refit manifold job done.
Approx 45 minute job
Shame you far away, i would have honestly done it for you
main worry with this job is if the o'ring has broken up, if so bits of it will be lodged into your inlet which will prevent coolant flow even if you replace the inlet. some poor bloke on clubgti had to take his inlet off 4 times before he managed to flush out a chunk of rubber and finally solve the issue. every time he blasted it with a hose it would move the oring somewhere and allow coolant flow, then as soon as he refitted it would move back and block it again!
o ring
