Need to change timing belt - does water pump need changing as well?
(In Topic #193647)
Standard procedure seems to include the water pump, but someone told me that the water pump is not connected to the timing belt syndrome (but rather to the alternator belt). In other words, no need to change them simultaneously.
Should I change both, or doesn't the water pump represent any hazard to the engine in terms of timing belt break-down?
You don't have to change the water pump but it makes perfect sense and doesn't take long either.
If your not familiar with the jobs, just take your time and be methodical!
COTM Team
The water pump is right at the front of the engine and easy to get to and run from the alternator belt. Replace the alternator belt as a couple of years is all they will last.
What colour is the coolant? Blue, pink, red or brown ish water? If a good colour pink leave it alone, Blue or Red might need changing soon, Blue every 2-3 years Red 3-5 years. Brown water change it NOW and take out the thermostat, you will need a new seal/rubber O ring.
You can see if the water pump is working when you start the car with the radiator cap off from cold you should see water coming into the expantion tank via the thin hose from the top of the radiator when you Rev the car the flow should increase as the water pump spins faster.
My 1,5 engine from 1982 hasn't got an expansion tank fitted. I observe similar models have such tanks, so have these been installed later? Should I get hold of an expansion tank and fit it into the engine bay?
As long as you keep an eye on the levels as you should with any old car you should not have a problem, I've not got a expansion tank on my Mk1 Scirocco and never had any problems in the 20 years I've owned it.
