need some help please
(In Topic #92964)
for a few weeks now the car has been starting really bad in the mornings (i put this down to cold bad weather)
the choke has not been kicking in in the mornings, so was useing the accelerator to keep the car going till it finally kicks in after 10 minutes then the car would be ok for the rest of the day.. but when its first started it sounds like its running on 3…
but the last week has been a nightmare.. been doing the same with the accelerator to keep it going in the mornings but when it would finally kick in i would take my kids to school no probs, but then a few days ago half way there the car will chug for a bit then just cut out in the middle of the road and again today !!
got the car back twice as its done this but it also drains the battery, had to recharge it twice…
brought leads and plugs yesterday and had them fitted, charged the battery and this morning its still doing the same. the car starts and still sounds like its firing on 3 (excuse the expression but sounds like a scooby lol) but cut out at my kids school.. so the car is still there at the moment till i can get it back..
any suggestions please as im pulling my hair out on this one and im no mechanic :dontknow:
oh forgot to add that the whole road is filled with black smoke when started in the mornings, and also the car suffers from really bad pre ignition
Firstly check you have no leaks from vacuum pipes, servo pipe etc, and the carb flange that sits in between the carb and inlet manifold.
Once you checked them, get back to me and i'll see if i can help you further fella
Pete :wink:
and love sounds better than fella (im female lol)
cheers mate !!
Pete
Pete
Also you need to consider the condition of your ignition system, dodgy HT leads are susceptible to the cold and a worn one could be causing your misfire. Pre-ignition can be down to poor carb condition (build of carbon on inside), bad fuel mix or even low/dodgy coolant. When do you get pre-ignition and what are the symptoms.
1983 1100 C
1983 1100 C
smoking
your carb mount and hoses may need changing ( easy job ) but black smoke doesnt sound too healthy, does it use a lot of water ? have you had a look in the rocker cover yet ? if there is greyish sludge in there chances are your head gasket has gone. but the only time i have had black smoke coming out the exhaust is when my piston rings had gone, or maybe a problem with the valves. my 1.8 auto cabby had greyish smoke coming out and the sludge in the rockercover and wouldnt start, had to skim the head and do a headgasket change, with all the parts, new gasket, new mounting flange, filters other parts and skimming head cost me about ?200
what part of the country are you in ? as i am sure you will be local to someone on here that could have a look for you, without paying stupid money for a garage
83 1.5 gl all black sold
86 1.8 gti cab all black light mods. restoring
87 1.8gti cab standard helios blue. daily driver
91 1.8 auto cab gold clipper. breaking
1983 1100 C
1983 1100 C
