more power
(In Topic #113895)
more power
if you're desperate though a GTI cam & k-jet 1.8 8v dizzy, plus a GTI 6 bolt manifold and downpipe would see you close to GTI power. If you stick with 8v power the manifold & downpipe at least can be retained on the new engine!
what would you say the easiest engine conversion is considering i dont have a lot of knowledge and will have to get someone to do it for me?also will it be a straight swap with a manual box apart from obviously the pedels.
cheers,andy
1.8/2.0 16v is almost the same amount of work, just you need to buy/make a 16v MK1 conversion manifold & downpipe or 4 branch, again these can be had off the shelf or made yourself
